COMPLETED Alpine 3656 Active Dividing Network
  • 2
Stilldouble
Sweden
Price
$400
Condition (1 worst - 10 best)
Fully configurable, 6-way signal division:
6 outputs: 2 Rear (Mid and High), 3 Front (Low, Mid and High) and 1 Subwoofer.
Separate Front and Rear inputs.
Capable of running a full system with front and rear channel fader.
Independent circuitry and outputs for Front, Rear and Subwoofer.
Continuously adjustable crossover frequencies.
Selectable Non-fading (constant), Front-fading, or Rear-fading Subwoofer output.
Independent crossover frequency adjustments for Subwoofer, Front Mid and Rear Low outputs: allow for staggering or overlapping the outputs to emphasize certain frequencies or eliminate resonances.
Phase switches for the Subwoofer, Front Mid and Rear Mid outputs: can be used to eliminate standing waves and system imaging problems.
Stereo/Mono switch for the Subwoofer output: allows the use of mono or single-speaker subwoofer systems.
Continuously variable output level controls for all outputs: allow compensation for different speaker efficiencies, amplifier sensitivity and/or system frequency response shaping.
24K Gold-plated RCA Input/output Connectors: for most accurate signal transmission, lowest loss possible, and immunity to signal deterioration that can be caused by corrosion in the connectors over time.
24K Gold-plated, screw-type power connectors: for optimum voltage, current transfer and excellent oxidization resistance.
High performance, low noise, audiophile quality active and passive components.
Trunk-mount, hide-away unit adjusted at the time of installation (no user-adjustable controls).
Remote-on indicator LED: confirms operation of the unit.
SPECIFICATIONS
Number of Outputs: 6 (fully configurable)
Possible System Configurations.
  • FRONT: 1, 2 or 3 way
  • REAR: 1 or 2 way
  • SUBWOOFER: on or off
Output Level Control Range: SUBWOOFER OUTPUT: 0 to +12 dB. ALL OTHERS: 6 to +6 dB
Overall Frequency Response: 10 Hz to 50 kHz (+0,-1 dB)
Signal-to-Noise Ratio: 100 dBA
Input Sensitivity (for 500mV output): 500mV
Input Impedance: 10kΩ ΜΙΝ
Output Impedance: 1kΩ ΜΑΧ.
Filter Type: Second-order Butterworth
Was Photo Included
  1. Yes
244
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
563
Bump, somebody has got to want brand new merchandise at crack head prices. I'm willing to wheel and deal.
14
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Stilldouble
Stilldouble
Sweden
Stilldouble
audiobaun
    May 19, 2024
    May 19, 2024
