Alpine 7909 #291/300
  • 4
Rob.
After a long search, numerous bumping threads, I finally got my Holy grail Alpine 7909 30th anniversary model, #291 /300.
Someone had contacted me stating they had a mint in box unit. I paid $700 shipped which was fair.
Anyways, I havent installed it yet, so heres some pics.
These units original came out in 88-1989ish and was top of the line back then (and still is today)
The limited 30th anniversary model came on in 1997, which Alpine only made
300 units. It had a copper plated chassis, better RCA cables and other refinements.
It recently won an award as the best ever sounding car cd player.
Original MSRP was $1200
The build quality, sound quality is next to none.
This is/was the must have unit for the Japanese audiophiles.
Alpine's 7909 Head Unit Wins 'Best Ever' CD Receiver Award
Added info:
Depending where you are in the world, there were 4 7909 models:
- 7909 U.S.
- 7909L U.K-EUROPE
- 7909J JAPAN
- 7909 30th anniversary edition U.S.
1.) The original 7909 has the "pull out" feature. Basically, you can slide out the head unit from your dash. While so many people jump up and down yelling, "that's cool," The consumers in Japan will not accept that. The pull out feature results in each connection, each contact meets a barrier since the 7909 basically "plugs into" it's cage. In other words, the signal is sent, met by the cage terminals but still needs to send that signal to your amplifier...it's not a constant flow. Alpine 7909 30th anniversary and 7909J, do not have the pull out feature and, each connection, each contact has a direct path to your amplifier. Believe me, that pull out feature was a major failure in the original 7909.
2.)The 30th anniversary and 7909J have small black box marked, "Alpine." That is actually a small external DC/DC convertor....the results is a cleaner power supply, cleaner signal and a more solid image. Original 7909 does not have that.
3.) 7909J has a "Black Out" CDS button. Press it and all tone control and lights circuits on the head unit are turned off. This allows a cleaner signal as a result of less interference and full voltage being needing to feed only the laser and spinning mechanism.
The 30th anniversary and original model has the CDS Button. It's a tone control bypass switch. There is an amber led that comes on when engaged. It bypasses the two sliders on the top of the unit....bypassing what is know as a noisier section of cd players. Cool feature.
4.) Vocals are cleaner. There's more detail with out the brightness that original 7909 has.
5.) 7909 30th anniversary and 7909J have Copper plated chassis for noise/interference reduction.
6.) All models play CD-R.
You guys think I should install this ?
That's your call. why the hell would you ask anyone else what they'd do with your stuff? :p
Up to you man, i'd keep it put up for years and sell it for more later.
Thats what Im gonna do for now. //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
471
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
691
I am willing to trade both subs for Kicker 46CK4 wiring kit $81 on Amazon https://www.amazon.com/dp/B07NS9DTWW/?tag=caraudiocom-20 T-Spec v12...
18
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Rob.
Rob.
Toronto Canada
Rob.
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
