Alpine @ 8 ohms
Jay Mack
I have an Alpine MRV-T757 that I'm going to use to power two 4 ohm, 12" Alpine subs. The amp is rated as fiollows, at 14.4 volts:
two channels at 4 ohms = 100 watts per channel;
two channels at 2 ohms= 200 watts per channel;
bridged at 4 ohms = 400 watts.
Now, what I'm going to do is wire in series (8 ohms) and bridge. What power do you think the amp will produce? 400 watts?
You're still getting 400 watts regardless. Wired parallel 200 x 2 @ 2 ohm vs. wired series (bridged) 400 x 1 @ 4 ohm. It's still 400 watts. Just wire the subs parallel to both channels.
8ohms bridged would be the same total power as 2 x 4ohms (100w x 2), so 200w.
The guy at Alpine says by doing it that way I'm back to 100 watts per sub, which I'm not sure I believe. He says it's way too little for the subs, which are Alpine SWE 1243s rated at 100 -250 watts. He made me go out and order a M500.1, which is made for those subs and which I did order just now from Crutchfield for $179.00. So, thanks alot.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
221
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
498
So far I have bought Kicker CWRT8D4 Subthump underseat enclosure for 8 LoopBack Harness from AIS 8 gauge Kicker wiring kit (Will run two 8 gauge...
13
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Jay Mack
Jay Mack
Wisconsin
Jay Mack
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
