Alpine PXA-H800 and RUX-C800
  • 1
307Bronco
15
Cheyenne
Selling my PXA-H800 and RUX-C800 digital sound processor setup. Mocked up in the vehicle but never played. Decided to go in a different direction and this no longer fits in my system. Need it gone. This combo retails for almost $1000 new.
PXA-H800
Product Highlights:
- Audio processor for use with any receiver delivers pristine sound to your aftermarket amps, speakers, and subs
- IMPRINT sound technology adjusts receiver output to match vehicle acoustics four 24-bit Wolfson digital-to-analog converters
Sound tuning:
- ImprintEQ with three presets and customizable target curves 31-band graphic EQ (front, rear, center) plus 10-band for subwoofer
10-band parametric EQ (front, rear, center) plus 5-band for subwoofer
- RoadEQ to help compensate for road noise high-pass, low-pass, and bandpass crossovers
- Bi-Phantom creates a virtual center channel surround sound decoding, plus Dolby Pro Logic II decoding
- 8-channel time correction
Connections:
- Alpine RUX-C800 wired remote controller (500RUXC800, sold separately) is required, unless using an "Imprint"-compatible Alpine head unit
- 6-channel speaker-level and RCA inputs (front, rear, center, sub)
- two digital optical inputs
- navigation voice guidance input (RCA)
- 8-channel high-power preamp outputs (4-volt, configurable)
Other info:
dimensions: 6-11/16"W x 2"H x 8-1/2"D
RUX-C800
- Controller for PXA-H800 digital sound processor
- BioLite display with red or blue illumination
- Lets you perform adjustments from your dash
- switch sources, mute playback
- dimensions : 6-3/8"W x 1-5/8"H x 1-1/8"D
Like New. Mock installed but never turned on
$600
Dependent on shipping destination
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
464
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
674
I am willing to trade both subs for Kicker 46CK4 wiring kit $81 on Amazon https://www.amazon.com/dp/B07NS9DTWW/?tag=caraudiocom-20 T-Spec v12...
18
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
307Bronco
307Bronco
Cheyenne
307Bronco
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
