Alternator - Any reason not to go bigger?
The biggest reason to recommend a 240-270a alt for a true daily is output at idle is almost always better than the larger 320a+ units ... other than that, there is not much of a reason to go with a lower output alt. if you can afford a higher output alt.
I ended up going ahead and purchasing the Autotech 320a
It was the best power per dollar option, and Samuel was super quick to respond and very helpful.
I'll update once I get it and install it.
Thank you everyone for the assistance!
Placed my order last Friday, Alternator shipped yesterday and should be here Tuesday the 22nd. Heck of a lot quicker than the quoted lead time.
Alternator arrived today.
It looks great. Samuel was very helpful, and even with powder coating, the unit arrived well under quoted lead time.
So far, so good 👍
So far, so good 👍 View attachment 35932View attachment 35933
@MinuteMan
How has that alternator held up for you ??
I just ordered a Brand X Alternator - 250 amp - $287
I am surprised nobody mentioned the following:
we recommend 250 amps as a maximum for stock idle rpm, anything over 250 amps may require an idle rpm adjustment, or larger crank pulley installed. 300+ amp alternators on the newer cars can cause bogging at idle and low idle Voltage because of this. The stock output on these cars is only 100 amps, going much over 2.5x the stock output can cause this. This is due to the very weak factory spring tensioner on the car, and not an alternator problem. For the most reliable options we suggest 250 amps or less and no modification is required for those options.
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
985
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
MinuteMan
MinuteMan
Massachusetts
All__Fun
    Jun 1, 2024
    May 31, 2024
