OP
My 320 amp Singer does that. Sometimes when you rev it up quick, voltage will jump to 16v+ for a split second. I'm not too concerned about it because it's not on my stock electrical circuit and my amps haven't protected. I don't think a spike for less than a second will hurt my batteriesAnd swinging load is normal? Cuz I feel like its not..
Sent from my SGH-T999 using Tapatalk
It's an adapter that plugs in the stoch plug and one wire to the back pos post in the alt to give a constant 12 volt signal to the regulatorWhat is this?
By stock plug, do you mean the one that went to my orignal alternator that's just left unplugged. I was given a new plug with my HO alternator thats wired to my fuse box to turn the regulator on/off with the car. I can wire it to stay on all the time but I don't see what the purpose is. Thanks for chiming in and trying to help me out.It's an adapter that plugs in the stoch plug and one wire to the back pos post in the alt to give a constant 12 volt signal to the regulator
the altrrnators now n days have built in regulators with a senseing circut to regulat the voltage. sounds like hte circuit or sensor is bad.. first pull the batteery and have it load tested..Does anyone else with a Singer Alternator have any noise coming from it when the car is off/key out of ignition. Gonna try and get some video of the voltage jumping around and maybe the noises its making if my phone will pick it up.
Sorry about the bad video quality, filming/driving stick inst easy but you can make out the voltage just fine.
voltage jumping around https://www.youtube.com/watch?v=f9uPs-ScpZU
noisy alternator at idle https://www.youtube.com/watch?v=GjQd_BJ5OGM
Both batteries tested fine.the regulators now n days have built in regulators with a senseing circut to regulat the voltage. sounds like hte circuit or sensor is bad.. first pull the batteery and have it load tested..
No it plugs in there as a pigtail. But there's a wire that is mounted to the pos postBy stock plug, do you mean the one that went to my orignal alternator that's just left unplugged. I was given a new plug with my HO alternator thats wired to my fuse box to turn the regulator on/off with the car. I can wire it to stay on all the time but I don't see what the purpose is. Thanks for chiming in and trying to help me out.
Not sure I'm following ya here. I do know my alternator use to be quite and had steady voltage so I don't see why I would need to change how its wired/installed. I just got done swapping stock alternator back in and no noises from it and my voltage is stable.No it plugs in there as a pigtail. But there's a wire that is mounted to the pos post
Not sure I'm following you here but either way this alternator use to be quiet and had a steady voltage. I see no reason to change how its installed/wired if it was working fine for two years.No it plugs in there as a pigtail. But there's a wire that is mounted to the pos post
Is this in the alternator? What was your solution?Had voltage issues like this with my singerI had a blown sense fuse
It is in the fuse box under the hood of my carIs this in the alternator? What was your solution?
