Amp Discussion
anyone bench tested a last gen powerbass asa1000.1dx? I feel like it puts out rated, even though its one of "those" brands lol
it's enough to pull my voltage down with a 200amp high output alt and a stinger spv-69c (not great obviously, but still).
Well, I guess it depends on what your definition of "near" is. However, the Elite of the Brutus line do in fact put out rated on music, anyway.
Dynamic power is clipping. That's why cheap amps gain so much that way and good amps gain little. The harder they clip right past clean the higher that number will be but it won't maintain it. Look at that as a real peak number
Thank you very much for the information //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
153
347
467
  • Locked
752
Amp
550
zdm
zdm
Houston, Texas
James Coyle
