amp installation help
rizzle1
im installing a 920watt power acoustic. i have everthing in place and wired correctly but each time i connect my rca jacks the amp give me a red led protector light. ive moved my ground from my rear car seat bolts to my trunk quater panel area still i get a red led protector light. any suggestions??? 97' cutlass surpreme
i had something similar happen. most likely your amp or sub could be blown. or the sub is too much power for the amp. when u put the rca into the amp, put only the positive in. if it works cool. take that out. put the negative only in. if it works cool. (weird situation that worked for me)
i tried that putting in one plug. but either way it turned red just when i put the rca's next to the amp lol
Best route is to start with a DSP. It will level and boost the signal with the option of having an amp remote trigger. For this you can tap before...
What size speaker wire would I need? would 16 gauge be ok or should I get 14? I definitely want to be on the safe side.
154
  • Locked
369
rizzle1
rizzle1
oklahoma
tEh ShOcKeR
audiobaun
    May 19, 2024
    May 19, 2024
