Amp light on no sound from sub
ssgtdj
MD
The ground wire on my amp recently came loose while was driving. Everything is hooked back up and the amp light is on, but no sound from the amp. It sounds like the sub tries to come on for a second. Do you guys think the ground coming off damaged the sub?
You could test the sub using a AA battery. Did you check your power wire fuse? It's possible the light is still coming on because the amp is still getting some voltage but not enough to power it up completely.
Yep it was the sub. I really liked that sub. Seemed like it should have been that the amp that got damaged. I took it back and got a refund. Thanks
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
Disconnect all 5 speakers and the rca cables from the amplifier. Turn it on and see if it still goes into protect. If it does, bad amplifier. If...
110
354
  • Locked
656
ssgtdj
ssgtdj
MD
ssgtdj
    May 31, 2024
    May 24, 2024
