Help Needed: Connecting Polk MM6501s and Polk MM651s to a Multi-Channel Amp
  • 2
blacksharpiemar
Canada
Hello all. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I recently purchased a 4 channel amplifier (specs below) and need some assistance wiring my polk speakers at a 2 Ohm load. My car audio knowledge is limited.
Here are the amplifier specs:
Class AB circuitry - 2 ohm stable
Continuous power
- 4 ohms (RMS) - 65 x 4
- 2 ohms (RMS) - 100 x 4
Bridged Power
- 4 ohms (RMS) - 190 x 2
Maximum Power
- 4 ohms - 130 x 4
- 2 ohms - 200 x 4
The amplifier is a Precision-Acoustics PA604 and has four (+ & -) output terminals.
How can I ensure the speakers are wired at a 2 Ohm load as opposed to 4 Ohm? Your assistance is much appreciated!
you take 2 4 ohm speakers . connect positive terminal on speaker 1 to positive terminal on speaker 2 . do the same for the negative side. now connect the + terminal on speaker 2 to the postive connection on amp . do the same for the negative. and boom there you go 2 ohm load. now im not sure if you wanna use a 2ohm load on a single channel or bridge 2 channels into one and do it that way. hope i could help
Thank you for the help. Now I finally understood :) Bass working fine now :) Life back to music ;)
4
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
128
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
630
blacksharpiemar
blacksharpiemar
Canada
chargdbassbuick
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
