amp not working
RJones87
I recently installed a Hifonics hifi1000.1d. The amp turns on, but it wont send anything to my subs. Im assuming there is suppose to be some type of voltage coming from the speaker terminal, but they read and 0v.
Should I return the amp or is there something I can try.
need to check power at the amp ,also check the remote for a 12 volt signal and the grounds continuity .then you can check the rca's for a signal .process of elimination
Seems to be a common issue with Maxxsonic's Monoblocks, I ran into this 3-4 MB Quart DISCUS 1500.1d's and a couple of the Brutus amps that shared the same board.
I would take it back imo.
dmm put the leads on the rcas ground and power and see if you get a reading . dont plug them in .this is why i dont buy or sell maxxsonics amps .have had the issue in the past with they're amps .
You can substitute another input signal to eliminate the HU and RCA cables. Plug an iPod or MP3 player or even a portable radio into the amp's inputs instead of RCAs. You'll need an adapter to go from the headphone to dual RCA plugs.
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
I’d suggest taking a methodical approach. Start with things you know work. Then add one thing at a time. Test the addition with a scope. Keep...
RJones87
RJones87
United States
maylar
    May 18, 2024
    May 18, 2024
