Amp power wire hook up.
  • 2
If you have multiple amps you do not need to run a power wire from each amp to battery..
You can have a single run of wire with a distribution block, it will then distribute a power wire to each amp.
Yes you want the fuse close to the battery.
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
JohnPD
CarAudio.com Regular
JohnPD
Ravenna, Ohio
deez283
Brendon Jenness
    May 8, 2024
    May 8, 2024
