Amp problem?
  • 2
SplAffair
I lol'd
I'm testing an alpine pdx 1000.1 1000 rms mono block. I'm setting my gains with my trusty DMM at 44.7 (square root of 2000 is 44.7xxxx) is it Normal to have to turn the gane about 3/4 of the way up to reach 44.7? I'm using a alpine cde-136bt which I believe is 2v pre amps.
There is no "normal" as there is no standard RCA pre-out voltage. The gain is there to match the input voltage, i.e. the lower the input voltage the higher the gain needs to be. You could have a very weak input signal that would require the gain to be at 100% and still not produce a clipped wave. If you're getting the correct output voltage you should be fine. Having an oscilloscope can be great for this however as you don't need to guess you're not clipping, you can just view the waveform itself and check...
I need to get one. How much are they?
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
855
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
761
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
60
SplAffair
I lol'd
SplAffair
Knocksville, TN
bubbagumper6
