Problem with amp and JL subs
  • 2
Ruizbra
CarAudio.com Newbie
The Problem: When I start my vehicle and drive or have it playing music for more then a minute, it goes into protection mode.
Specs: 2x JL 8inch 8w3v3-4 amps 4ohms separate and 2 ohms on parallel.
1x 2 channel 750w bluapunkt amp rated 4ohm and 2ohm stability
What I've test so far: I have check ground and resurfaced, Ran 2 ohm parallel (2.3ohm reading) , Separated for 4ohms 2 channel(4.2ohms each), Getting 14.4 volts constant, and running min gain.
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember that getting full voltage does not guarantee a strong connection.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
661
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
699
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
The starting ask on diyca.com is $2,500, so no telling what they want in the end, maybe $500k lol. Funny that caraudio.com is no longer valid for...
19
76
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
917
Ruizbra
CarAudio.com Newbie
Ruizbra
United States
1aespinoza
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
