an amp for my jl subs
  • Thread starter <jl>
  • Start date
  • Replies 1
  • Views 1K
  • 1
If price is no problem, it's kind of a moot question. Rockford's are always great with JL's, Excelon, MA Audio, Xtant, Kicker, MTX, the list goes on. Those were just the ones that came to mind. Just don't buy at Wal*Mart (Or any other *mart for that matter.) and you'l be fine.
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
963
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Guest
locomc
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
