what amp 4 hx2's
  • Thread starter <john>
  • Start date
  • Replies 5
  • Views 1K
  • 3
you can get a sony 3001sxd for around $200. it is rated at 1000 watts at 1 ohm. since the subs are dvc, you can wire the coils on each sub in parallel and then wire the two subs together in parallel for a 1 ohm load.
First off dont listen to Kithut84, do not lower the ohms to 1 ohm to each sub, u might blow ur sub doing that. The RF power 800 is a good amp, and the RF bd1000 is good. whatever you do, do not wire everything to drop the ohms to 1 ohm.
shocker, why would that blow the subs? they are rated at 500 watts rms each (1000 total if you can add) and the amp is rated at 1000 watts at 1 one ohm. 1000 watts going to subs that can handle that power would not blow them unless you have the gain too high. dumbass
Originally posted by Shocker28:First off dont listen to Kithut84, do not lower the ohms to 1 ohm to each sub, u might blow ur sub doing that. The RF power 800 is a good amp, and the RF bd1000 is good. whatever you do, do not wire everything to drop the ohms to 1 ohm.
How is lowering the impedence of the subs going to blow them ? If the sub can handle the power. I don't see the problem.
[ 12-28-2001: Message edited by: ramos ]
6
117
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
295
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
303
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
362
Guest
ramos
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
