any safe way to remove/cut body bond material?
  • 3
ntense702
Las Vegas
well when I got my body kit installed and painted I had the front end molded (big mistake). so today I tried to install my new altezza headlights and come to find out in order to remove the stock headlights the whole front end has to come off to get to the main bolts behind them. so anyways is there anyway I can remedy this situation and cut/remove the molding, cause my stock headlights look like
sh!t //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
did they use fiberglass to mold the body kit to the car, epoxy or just plain bondo.
bondo will soften up with paint striper. the other two will have to be cut off. i think.
try to find where the gap would be and tape it and use a cut off tool and cut threw the material, i say use the tape so ur paint is less likely to chip
There aren't many wires coming off the amp. There's: power in (12V Batt +, usually the big red one), power out (Ground, usually the big black...
5
Hello, I am getting ready to install my 3000 watt taramps and 2 15s in an expedition. I am a little hung up because my old car had a 220 amp...
Cant use the scope because the amp is plug and play. Can only set it up by ear. Will I hurt the speakers by playing a 1000hz tone at 75% volume...
ntense702
ntense702
Las Vegas
THUNDERBIRD
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
