At least i got started on the S10
Ive got along way to go , but alittle here and there and it will have sound soon .
Got all the wire and 2 s3400 xs power batteries , ho alternator , NRG terminals , so i thought i can start on it .
another set of NRG Terminals heading my way ,need a 4 channel amp and might look into having a custom box made //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hopefully will get what i have installed over the holiday break since work has been busy . Doing some slight mods to a box i got for a s10 and from there need to decide on having a new box built or maybe change subs . Should get me started thou .
Since i picked up a box made for a s10 to use for a short time , I needed to do a couple little things to match my interior better and make some room for the battery i have . The box is a little small for my subs but this will give me an idea on how i want the new box built in a month or two.
I wasnt sure on how to carpet the round corners on the inside of the amp rack cover and on the top panel where port is but it looks decent . The new carpet material i got is thicker then what was on it so i will have to cut and redo the amp rack cover and the access panel under that and finish up the covering . Should be up and going by Monday unless i get called into work .
Ehhhh. Won't be that loud. Trust me. I've tried every configuration in my old s10. Actually still got the old box. I was doing 153 in my truck subs up port up drivers side was the best for me
Are those 10's or 12's?
They are 12's
That was the way i had planned on going . I picked this up to try and till i decide what to do .
Been so busy with work but finally got something done . Maybe i'll get the rest in before the weekend ends . Bottom part is all mounted and bolted in . Sound deadened the floor , and the back , side panel areas . Got the doors and roof to do now . After this is all in , i'll rethink subs and have a new box built .
Timewarp
Timewarp
Brevard,Fl
Timewarp
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
