Attn: Zane - Amp capabilities
  • Thread starter <jaylee>
  • Start date
  • Replies 4
  • Views 2K
  • 3
<jaylee>
Guest
I'd like to know if most quality amps can go below their rated ohm load without overheating. And if so how far below.
I have a Crossfire CFA302 amp that's rated 300Wx1 @ 4 ohms. Do you think it could run a higher output at 3 ohms safely???
I would test the theory myself but I don't have the subs. I'm going to buy one soon and was thinking of getting a DVC 6 ohm instead of the DVC 2 ohm to get the most from my amp and I don't want to hassle with any returns since i'm buying online.
I'm looking for some expert advice and the local stereo shop could f@#! up a boiled egg.
Thanks.
Many amps can run below their minimum ohm rating. It's seriously not recommended since you could damage the amp. I mean, I've had Ma Audio amps that are rated for 1 ohm and run them at .5, and have had even Jensen amps running down to 1 ohm. SO it could be done, I wouldn't though. You'll lose lots of clarity, definition, and efficiency. It's not really worht it unless you've got the power and are just burping the subs.
Typically as stated, an amp usually can go slightly below its rated ohm load. Usually it is best to stay within the amps rated guidelines however. When you get into the higher quality/ Class D amps- then you can usually push them a ways under thier rated limit.
Crossfire Usually holds its own quite well at 2ohms, so the 3 ohm load should be no trouble.
Some amps that are capable of exceding their ohm rating are commonly:
Cadence
Soundstream
Harrison Labs
Synopsis
MTX
Rockford Fosgate (power series)
Mmats
Memphis
Zapco
Phoenix Gold
PPI
etc, etc, etc,
Take it easy,
-zane
About all the amps can drop down another notch to 4 ohms to 2ohms without any problem so I'm sure you'll be fine just don't try to do lower or bridge it when it doesn't say bridgeable
6
117
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
294
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
303
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
362
Guest
BigAudioJoe
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
