how to wire 2 DVC subs to rockford 1000.1 amp
  • Thread starter <muff_man_aj>
  • Start date
  • Replies 2
  • Views 2K
  • 2
I'm pretty sure those subs have 4 ohm voice coils. So run everything in parallel. Run all the positive connectors to the + connector on the amp and do the same for the - connectors. That'll give you a 1 ohm load on the amp and it should handle it fine.
Alpine's can usually take a lot power and rockford amps can usually kick a lot of power and are bridgeable and stable at low impendance so bridge them like the other guy said -to- +to+ and to one speaker and parallel to the second and you'll be fine.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
89
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
556
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
902
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
873
Guest
BigAudioJoe
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
