Audison LRX 300.4
bump465
Arizona
High Power 4-Channel Amplifier
RMS Power Output:
4 Ohms: 65 watts x 4 chan.
2 Ohms: 105 watts x 4 chan.
4 Ohms Bridged: 210 watts x 2 chan.
PWM MOSFET power supply
2-Way Butterworth Crossover: High Pass @ 12 dB/oct. and Low Pass @ 12-24 dB/oct.
RGP(Resettable Ground Protection) Circuit
Darlington configuration
Compact design
Line Input and Output
S/N Ratio: 105 dB
THD: 0.009%
bought this amp second hand 3 years ago so beyond that i have no idea how old it is.
Amp sounds amazing and gets pretty **** loud. has awesome tuning filters, by far the best a/b i have ever owned. I used it for maybe about 2 years. never had any problems with it, full disclosure, my 6x9 knocked the wire out of itself once and the amp protected flawlessly I continued to use it without incident for another year until i got a new car.
adjustable slope cutoff
power limit led (clipping light)
interchangeable subsonic filter resistors
Independent stereo/mono channel operation
quality german construction
power and speaker terminal screws are worn quite heavily but can easily be replaced. The amp itself has moderate cosmetic wear but nothing bold or aparent a few light scuffs and a scratch or 2 down the heatsink.
I also want to emphasize that 105 S/N ratio and .009THD youll be amazed what "105" watts sounds like
250+Ship
Shipping from 80227
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided
http://s1042.photobucket.com/user/dh465/library/lrx%20300-4
Pm'd. Iv never used photobucket before but will look into how to do so and try to upload again when im home from work at 10pm. I can send pics via text until then.
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
Yes mate I have these in a 3 way active front stage and they sound great, have them crossed at 5k, see my recent post for full breakdown of kit I...
bump465
bump465
Arizona
bump465
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
