SOLD Audison SRX2S
  • 3
blackmax
This is in great condition I am just cleaning house (garage). $175 shipped. Will consider trades (up or down) for an eq or one or pair of 12's for my wife's car. Her amp is rated at 500 watts at 2ohm (mtx thunder895).
Here are all of the specs for those that don't know how to search.
POWER SUPPLY
Power supply voltage: . . . . . . . . . . . . 11 ÷ 15 VDC
Idling current: . . . . . . . . . . . . . . . . . . . . . . . . . 0.9 A
Idling current when off: . . . . . . . . . . . . . . 0.002 mA
Musical max consumption: . . . . . . . . . . . . . . . 35 A
AMPLIFIER STAGE
Distortion –THD (1 kHz; 4 Ohms): . . . . . . . . 0.03 %
Bandwidth (-3 dB): . . . . . . . . . . . . . . 4 Hz ÷ 50 kHz
S/N Ratio (A weighed @ 1 V): . . . . . . . . . . . . 95 dB
Damping factor (1 kHz, 4 Ohms): . . . . . . . . . . . 280
Pre In input sensitivity: . . . . . . . . . . . . . . . 0.2 ÷ 5V
Speakers In input sensitivity: . . . . . . . . . . 0.4 ÷ 10V
Pre In input impedance: . . . . . . . . . . . . . 15 kOhms
Speakers In input impedance: . . . . . . . . . 100 Ohms
LOAD IMPEDANCE:
2 ch. . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 - 2 Ohms
1 ch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Ohms
NOMINAL OUTPUT POWER (RMS)
NP @ 12VDC; THD 0.3% 4 Ohms:. . . . . . 135W x 2
OUTPUT POWER (RMS) @ 13.8 VDC; THD 1%:
- 2 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . 180W x 2
- 2 ch (2 Ohms) . . . . . . . . . . . . . . . . . . . . 300W x 2
- 1 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . . 600W x 1
FILTERS/INPUTS
Inputs: . . . . . . . . . . . . . . . . . . .Pre In / Speakers In
Outputs: . . . . . . . .Pre Out (hi-pass/bypass/lo-pass)
Filters: . .12dB-24dB/Oct., hi-pass / bypass / lo-pass
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .50÷350 Hz
Lo-pass switch: . . . . . . . . . . . . . .stereo (12dB/Oct)
. . . . . . . . . . . . . . . . . . .mono (24dB/Oct) / bypass
Q control:
(on hi-pass) . . . . . . . . . . . . . . . . . . . . . . . .Q 0.7÷2
OTHER FUNCTIONS
Remote IN: . . . . . . . . . . . . . . . 7 ÷ 15 VDC – 1 mA
Connections for VSR kit
for SUB remote volume: . . . . . . . . . . . . . optional kit
Fuse: . . . . . . . . . . . . . . . . . . . . . . . . . . . strip, 30 A
Protection: . . . . . . . . . . . . . . . . temperature >85°C,
DC voltage, overload
Green-red LED indicators: . . . . . . . . . . . . on-safety
Cooling fan: . . . . . . . . . . . it activates from 55°C on
MAX SIZE (D x H x L): . . . . . .178 x 49.5 x 440 mm
blackmax.....how old is your Audison amp? Looks to be in pristine condition. I'm in the market for an amp to run either DLS UP6i 2 ways, or Dynaudio Esotec 242 GT's. How would this amp fare with either of these components?
Kevin.
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
Yes mate I have these in a 3 way active front stage and they sound great, have them crossed at 5k, see my recent post for full breakdown of kit I...
blackmax
blackmax
Boise Idaho
Kevin Boyer
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
