Beefy ford alt!!!
  • 3
if it can hold what an 03 expedition holds i can get you a steal on my buddies whos is brand new from mechman. i think it does 175 at idle which is pretty nice... he never ended up installing it and is prepared to take a loss
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
815
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Timmy13091
Team DC
Timmy13091
Chicago
cdimic25
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
