BMW 6 Series, XM and IPhone
  • 4
92sdimenj
Customer wanted XM Radio and I Phone Mounted and installed into the veh...wanted something simple so this is it....Enjoy.
Basically used the mount with the xm commander to flush it into the panel, as for the I phone, i took out the factory ash tray and made a piece of ABS to fit in, covered that in black Vinyl and inserted the factory cig lighter, then cut out and mounted a iphone dock into the peice allowing it to charge the phone and play music via aux from the base into the Aux in the BMW glove box.
Only thing left was a nice billet cig plug
Look at Recoil components front and coaxials rear. Cheap solution. The Taramps is fine, or Recoil, or blackbrick 100.4 for $69 shipped. More...
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
977
I have a pair of IS BMW 100L on order. The next upgrade will be the center and/or the amplifier. The Focal center is much cheaper, however many...
Sounds like you already have a plan. Hook it up and let us know how it worked. Good luck.
92sdimenj
92sdimenj
East Brunswick, NJ
92sdimenj
    May 18, 2024
    May 16, 2024
