Bose amp wiring harness for 2014 mazda cx5
  • 2
ziggy@2022
16
usa
Hello, I was wondering if anyone could help me out ? my issue is I have a 2014 mazda CX5 grand touring edition thats came with the bose amp package I believe the amp is bad and I would like to bye pass the amp and add a four chanell aftermarket I just don't know what wires to tape into ? if I wanted to replace the factory radio as well and add a amp and also replace the front speakers with a set of components . if that is the case where do i tape into the speaker wires is it behind the factory radio or is it at factory amp location and if that's the case which harness has my speaker wires ? I am adding an image is it the green harness or the black one ?
44751
Make sure your speakers are 2 ohms or higher or you'll have problems with the aftermarket amp. Do you know if your speakers are actively or passively crossed over? Might want to check a Mazda forum for more insight.
I know the car came with two ohm speakers in all the doors I am replacing them with a set of aftermarkets components up front and a set of coaxials in the rear , they are 4 0hm . the mazda forums have not been much help , I think the front has a set of factory components meaning the tweeters in the dash provide the highs and the lower door speaker is meant as a mid bass
Kicker 46CSS654
CS Series 6-1/2" component speaker system
chose these for the front chanel
Kicker 46CSC654
CS Series 6-1/2" 2-way car speakers
rear speakers
Soundstream Reserve RSM4.1200D
Compact 4-channel car amplifier — 75 watts RMS x 4
well ****, thanks anyways. Will leave the thread open just in case someone knows anything :)
@1aespinoza I see, so this audio volume leveling is what I was experiencing tapping into the Bose sub wires. Well then, I'm off to check out the...
The harnesses showing up for your vehicle show one or two adapter plugs. If your car has a separate CD player, then I assume that is what the 3rd...
Yeah, I really enjoy this site's members. There is so much combined knowledge and camaraderie that it is difficult to stay away. Yes, alot of us...
853
ziggy@2022
ziggy@2022
usa
ziggy@2022
audiobaun
    May 19, 2024
    May 19, 2024
