Boss Audio R3400D setting gain level
I highly doubt that it makes 900watts at most 500 with 14v and will probably fry in a month
its cheap.. however I have had it for 3 months now and it works just fine.
900 * 2 sqrt = 42v, is this what i should set it to?
No lie, I cracked my mono "3000w" boss amp to like 70-80% an the 2chan "2000w" was set at like 50%. My highs wud cut out after 30mins, the sub never even got warm. I had it for about a year, got rid of the whole truck. System still worked....
If you have 2 d4 subs wired parallel you are at 1 ohm which equates to no more than 30v ac.
they r single 4s **** it. any one else want to tell him his single 4ohm subs can't be wired to 2 ohm. he needs to know how to set the gain not what he's wired to.
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
214
sta
sta
Norway
sta
maylar
    Jun 2, 2024
    Jun 1, 2024
