Box Building Help/Questions
  • 3
it depends what kind of box if sealed its sounds like **** but if ported sounds not so bad. i would put walls in between in a sealed box thats the right size for your subs
it depends what kind of box if sealed and no walls its sounds like ****, but if ported sounds not so bad. i would put walls in between in a sealed box thats the right size for your subs
i dont know if they will necessarily "cancel" each others sound out... but, if you follow the manufacturers specs for interior box volume per sub, you will get more output from each sub than if you had just one large box with multiple subs in it!!! if done right more output from each sub can lead to better SQ as well more SPL.
The crossover is just a pair of 3way, 300watt crossovers I picked up from from amazon. the subs I have are 8" Kicker FreeAir f8a I am looking...
4
835
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
501
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
661
CheapPyramidStuff
CheapPyramidStuff
Kamloops BC Canada
imral3
