box designs
  • 5
No.
In a sealed enclosure, the smaller it is (in proportion to nominal space) the more abuse it can take. (I.E. take more RMS power than rated for longer.)
In a vented enclosure, the less air space is more pressure that the woofer is working against. Larger enclosures will produce higher numbers, but risk over-exerting the driver, as well as over-working the coil.
You want Spl, you tune the box higher than normal, if thats what you mean. Usually a box is tuned somewhere in the 30-38Hz range, for music. In spl, its usually higher than that.
Smaller boxes are used because you can throw more power at the sub(s) without it overexcurting. Try putting 3kw to an 18" SX in a 7ft^3 ported box and you'll see that it'll overexcurt very easily. Now put it in 2ft^3 and put that same 3kw to it, and voila, you're fine(generally speaking).
Obviously, this is a very simple way of explaining it.
I love words like 'generally.' Just to cover our ass in case ish goes bad.
No.In a sealed enclosure, the smaller it is (in proportion to nominal space) the more abuse it can take. (I.E. take more RMS power than rated for longer.)
Please do not take about what you do not know, we're talking SPL here............ And besides, a sealed box won't increase thermal power handling, so it won't magically make the sub take it's RMS for "longer". You just have good cone control.
The loudest box I ever used in my street C set-up was a hair over 3 cubes for 2 15's //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif It all depends on the application.
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
471
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
657
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
973
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
782
Anwar ( Team Pi
Anwar ( Team Pi
South Africa
Pyro_By_Nature
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
