Box Help For 3 AQ HDC3 10s on a AQ 3500.1 PLEASE HELP
  • 2
EXTREMECHEVYMAN
Vehicle : 94 Chevrolet FS Blazer 2dr K1500
Location in the vehicle: rear
Space available (Length x Width x Height):
Subwoofer make and model: HDC3 copper
Subwoofer Size: 10''
Number of Subwoofers: 3
Type of Port (Kerfed, Slot, Aero, etc.): slot
What type of music do you like?: all
Is your goal SPL or Everyday Music?: spl
Tuning Freq (Hz): 40-45hz
Volume : 5.5
AMP: AQ 3500.1
Questions:
I have set an come up with this but don't know if it would be good enough.
36w x 24d x 18t
7.41 internal volume
6.0762 net volume
before subs an port
4.7012 net volume after port an subs
97.2192 sq'' of port area
can someone help. would this be good. want to make sure port will be right around 40hz.
36w x 24d x 18t
Box Parts (Square Prism)
1 Top, 1 Bottom: 24© x 36(b) in 0.75 (Thick) in
1 Front, 1 Back: 16.5(a) x 34.5(d) in 0.75 (Thick) in
2 Sides: 16.5(a) x 24© x0.75(Thick) in
Vent Parts
1 Top, 1 Bottom: 6.5(e) x 16(h) in 0.75 (Thick) in
2 Sides: 18(g) x 16(h) x 0.75(Thick) in
Misc Objects Inside Or Part of Box
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
718
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
EXTREMECHEVYMAN
EXTREMECHEVYMAN
Washburn, Tennessee, United States
EXTREMECHEVYMAN
    May 18, 2024
    May 18, 2024
