Box help
Randy Savage
New York
I need help making my box, as it is my first attempt. I just purchased 2 12" Audiobahn AW1206Q subs, rated at 1100 watts rms each. In a few days I will most likely be ordering an MA Audio 4002 4000 watt 2 channel amp, and I need help with the dimensions that I will make the box in, It will most likely be a sealed enclosure with a plexiglass cover on top of it. Any help or suggestions would be appreciated, thanks.
First I WOULD LOOK AT THE SPEC. SHEET FOR YOUR SUBS. AND DETERMINE WHAT AIRSPACE THEY REQUIRE. THEN MAKE YOUR MEASUREMENTS AND GO. (CUFT. IS LxWxH/1728)//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :) EX: 12x12x12/1728 =1 cuft ( internal dimensions)
Originally posted by snova031 I need help making my box, as it is my first attempt. I just purchased 2 12" Audiobahn AW1206Q subs, rated at 1100 watts rms each. In a few days I will most likely be ordering an MA Audio 4002 4000 watt 2 channel amp, and I need help with the dimensions that I will make the box in, It will most likely be a sealed enclosure with a plexiglass cover on top of it. Any help or suggestions would be appreciated, thanks.
What kind of car ?
Nah just checking for room. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Now next question what kind of music do you listen too ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
824
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
Randy Savage
Randy Savage
New York
Randy Savage
    May 31, 2024
    May 24, 2024
