RMF419 10+ year member
Can someone run these specs thru their box building program and see what size box it comes up with. I am coming up with a huge box. Thinking these may be good IB subs. these are the numbers. It features dual 8 ohm voice coils, poly cone with rubber surround, vented pole piece, and bumped magnet back plate. Specifications: *Power handling: 150 watts RMS/300 watts max *VCdia: 1-1/2" *Le: 1.24 mH *Impedance: 4 ohms *Re: 2.65 ohms *Frequency response: 27-1,000 Hz *Fs: 27 Hz *SPL: 86.5 dB 1W/1m *Vas: 3.15 cu. ft. *Qms: 9.83 *Qes: 0.65 *Qts: 0.61 *Xmax: 6.0 mm *Dimensions: Overall diameter 10", Cutout diameter 9", Depth 4-1/2". Note: All specifications are with voice coils connected in parallel. Thank You...
