Bridging a four channel with speaker level inputs...
  • 1
86svo
Ok, in my 04 Ranger I am retaining the stock deck since I'm just doing a budget system and I have ran all my wires and the front components sound great, the only problem is I'm not getting a signal when I try to bridge 3&4. This is an Alpine F-300 so it is a 2,3,4 amp and I'm using it as a 3 channel.
The way I have the speaker level inputs wired are green and white to front left side positive, white/black and green/black to front left side negative. Then I have Grey and violet to front right side positive, grey/black and violet/black to front right side negative.
Now I can get a complete signal if I hook the sub up to a single channel, but when I try to get the bridge....nothing. Did I not wire up the input levels correctly? It seems as though it should be accurate, but not too sure? Anyhow, any help would be great, thanks!
Jason
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
981
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
833
86svo
86svo
Canton, Ga
86svo
    Jun 1, 2024
    May 31, 2024
