Burning/Melting smell from alternator/amp/speakers/sub/receiver?
  • 2
Alimoose
Today I just noticed that if I set my receiver on pause for CD/USB whichever, there is a burning/melting smell after a while. It would go away after I un-pause it. Now, the same thing happens when I turn up my volume above 20 (0-50, with loud enabled, JVC unit). I get this burning/melting smell. It would go away if I lower the volume below 20.
I have no idea what is causing this.
I had my factory stereo system before the JVC unit and above 2/3 volume, the smell would come in also. So, I'm pretty sure its not the unit. There is no smell coming from the subs/amp when I opened the trunk. So, I don't believe its the amp/subs. The smell was there when I had my factory speakers in too. So I also believe its not the speakers. I could be wrong of any of these.
Dimming of the lights do occur. I did the big 3 cables. Alternator (Factory) and Battery (Die Hard Gold) hasn't been changed. No capacitor. I still unsure to even get this. The store I go to tells me to get a cap because I'm running above 1k watts, but then others are telling me its useless.
I got my alternator checked and they said it was working in perfect condition, but obviously its not juicing my system up. As of right now, I am not changing the alternator for whatever reason.
Anyways, any ideas of what could be causing the smell?
The current system I'm running:
1999 Toyota Camry LE
JVC KW-XR610
Rockford Fosgate Prime R1693 6" x 9" Rear
Rockford Fosgate Prime R1653 6-3/4" Front
Hifonics Brutus 1600 Watt Mono D-Class Trunk
2x 12" Alpine Type R 500 Watt Trunk
Big 3 cables @ 2-gauge
Probably the voice coils on your speakers burning, when you clip them or put too much power to them it burns the laquer that separates the wire on the coils. smells like poop. turn your shiz down, you either have your gains up too high or your burning the door speakers and should replace them. also the loud function is a waste. getting a second battery is also not a bad idea.
I can understand the voice coil situation...but the thing is, I had it on pause and there was the smell of burning/melting also?
Also, this happened with my factory speakers also. I had factory speakers and factory head unit. @ 2/3 volume, the smell comes.
Your dad must of used tape for condoms and that is how you got here? He shoulda used more tape..
25
3K
Honestly thinking of just putting my bose speakers from my other car and the shallow 10" woofer in the car in driving now. The bose system in my...
39
5K
Sorry I was drinking and thought he was blowing fuses. That Pabst Blue Ribbon gets me every time.
23
nice! yeah i don't know if that would be enough or not for the bigger setups... people here say it's enough for easily 10kw but i'll research...
14
Alimoose
Alimoose
Tampa, FL
Alimoose
