kirby mane 10+ year member Member 120 0 Tuscaloosa,Al Dec 12, 2012 #1 Has anyone used or heard any of Cadence new speakers? And are they worth buying? looking for a pair of shallow mount 6x9s thanks. Click to read more...
matt_bennett05 10+ year member mattchoo! 3,503 1 South Westerly Georja Dec 13, 2012 #3 Never heard them but I know the high end PA stuff got good reviews. Keep bumping this thread, you'll get a response
TreyE 10+ year member CarAudio.com Veteran 3,957 0 Tampa Dec 13, 2012 #5 Shallow mount 6x9's? Always thought 6x9's had the least mounting depth problems being in the rear deck..... I feel like everything shallow mount s u cks, whats the mounting depth you have available?
OP kirby mane 10+ year member Member 120 0 Tuscaloosa,Al Dec 13, 2012 Thread Starter #6 measured factory speaker its 2 7/8 inches its for the front doors in a 2007 charger. the alpines i have in the now are starting to blow had them for a few years.
AnthonyO 10+ year member Budget Banger Connoisseur 3,562 485 Minot, North Dakota, United States Dec 13, 2012 #8 Whats the model number of the ones you are looking at?
OP kirby mane 10+ year member Member 120 0 Tuscaloosa,Al Dec 14, 2012 Thread Starter #9 Zrs-69s and cs3.69
OP kirby mane 10+ year member Member 120 0 Tuscaloosa,Al Dec 14, 2012 Thread Starter #10 Bump or should I go with powerbass s92t those are the only shallow mounts I've found
AnthonyO 10+ year member Budget Banger Connoisseur 3,562 485 Minot, North Dakota, United States Dec 14, 2012 #11 The ZRS-69s will work. The CS3.69 will not as they have a 3" mounting depth.
Joseph7195 10+ year member Walkin Tall 1,519 3 Saltillo, Mississippi, United States Dec 14, 2012 #12 Hey! The zrs line is a very good line. They have a lot of different lines, and depending on your application, one will fit what you need.
TreyE 10+ year member CarAudio.com Veteran 3,957 0 Tampa Dec 14, 2012 #13 you can put spacers/washers to make extra space if you need an extra .25" or so
