Can I get a modern take on amps?
Power is a lot cheaper these days and amps for the most part are more efficient...especially the multi channel class d amps...I can't tell the difference between a good class d 4 channel and an good ab sound wise though 🤣
Most of the good brands from back in the day (soundstream, mb quart, ppi, hifonics) aren't nothing compared to what they were...Even orion seems a shadow of its former self the way the cobalt line of amps are way over rated...
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
904
Just the amplifiers use batteries to power it up. The HU are powered up by the car battery supplying 12 volts. The wiring harness...
6
Hey kids. I see modern head units have 'pandora connectivity' an other stuff. How do these work? Are they, say, a pandora app on the device...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
158
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
417
mccar
CarAudio.com Newbie
mccar
1 star state
spokey9
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
