can i use 2 car batteries?
  • Thread starter <chickenman>
  • Start date
  • Replies 2
  • Views 2K
  • 1
<chickenman>
Guest
instead of wiring everything in the trunk to the battery under the hood can i just put a battery in the trunk so that i wont have to use so much wire?
i wish that way was as easy as it may seem. but it's not. if you have 2 batteries in your car, that extra battery has to be charged by the alternator. and if you have a stock alternator, then you might have to upgrade you alternator to a more higher output so it will handle the 2 batteries. the process is expensive becuase i did it myself. you have any questions, feel free to email. jsons2fly@yahoo.com
Originally posted by :i wish that way was as easy as it may seem. but it's not. if you have 2 batteries in your car, that extra battery has to be charged by the alternator. and if you have a stock alternator, then you might have to upgrade you alternator to a more higher output so it will handle the 2 batteries. the process is expensive becuase i did it myself. you have any questions, feel free to email. jsons2fly@yahoo.com
Not to mention the fact if the batteries aren't identical you need either a solenod or an isolator. And an extra battery will put more strain on an alternator. Whch is the last thing you need when your trying to squeeze all the current out of it you can.
414
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
723
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
584
Guest
ramos
audiobaun
    May 19, 2024
    May 19, 2024
