I have a boston 5 channel gta1105 amp, it says 400rms to the d channel at 2 ohms and cvr12 is 2ohm sub at 400rms would that be ok and not blow it. Also that seems like perfect power ratio?
so what if I take a 4ohm alpine type s sub and just follow the diagram to wire it as a 2ohm sub would that work. I always thought a 2ohm sub would just plug in as 2 ohm.
also the kicker is this Kicker - CompVR 12" Dual-Voice-Coil 2-Ohm Subwoofer
it says duel voice coil 2ohm sub so it should be plug in play but I guess Im just confused.
the alpine says duel voice coil 4 ohm sub, so the alpine works then correct/
