Planet Audio p1502 at 1ohm bridged opinions
  • 1
grandam888
I am just wanting opinions on running my old school zed made planet audio p1502 amplifier at 1 ohm bridged. These amps are hard to come buy, and the last thing I want to do is fry it.
My plan is to set it up to run at 600-700 watts via multimeter to keep the ameperage down. The final load of my subwoofers is 1 ohm after box rise I may be okay.
Just wanting opinions on, maybe from someone with experience doing this. Specs of amplifier.
150Wx2 @ 4ohms 220Wx2 @ 2ohms 300Wx2 @ 1ohms 440Wx1 @ 40hms bridged 600Wx1 @ 20hms bridged
10Hz-100Khz -3db Input signal sensitivity (gain) 100mV-5.7V SNR=103dB 9"W x 2.5"T x 14.2"L 55-4.2HZ HP/LP filter Bass boast 0-12dB
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
179
grandam888
grandam888
houston, tx
grandam888
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
