CDT Audio MA-7504 4-Channel Tiny Amp
  • 1
trumpet
Barry Schanz
1 available
New, slight cosmetic flaws
Class AB design
Features:
  • MOSFET power supply
  • Plated brass set screw terminals
  • 12 dB/octave crossovers
  • variable high pass crossover (30 Hz - 500 Hz)
  • variable low pass crossover (30 Hz - 500 Hz)
  • Variable 0 dB to 12 dB bass EQ at 45 Hz
  • 5 Way Protections
  • Daisy chain through output RCA
  • Power and protection LED
  • 2 ohm stable
  • Soft start/mute circuit
Technical specs and contents
  • Power Output:
  • RMS @ 4 Ohm: 55WX4Ch
  • RMS @ 2 Ohm: 90WX4Ch
  • RMS @ 4 Ohm 120WX2 mono bridged
  • S/N Ratio: >95dB
  • THD: 0.05%
  • Channel separation: >50dB
  • Input sensitivity: 0.1V-8V
  • Input impedance: 47KOhm
  • Slew rate: 10V/msec
  • Damping factor: 200 At 4 Ohm
  • Fuse rating: 40A
Dimensions
  • Width: 139.5mm
  • Height: 46.7 mm
  • Length: 220. mm
$250 shipped to the lower 48 states
Worldwide shipping is available. PM me for a quote.
Get 2 MA line amplifiers for $425 shipped.
Buy 3 MA line amplifiers, the 4ch, the 2ch, and the monoblock, all for $600 shipped.
All 3 models have the exact same physical dimensions. This makes your system layout symmetrical and easy to design.
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
    May 31, 2024
    May 24, 2024
