Chevy spark
I don’t want to wall it yet since it’s my daily still using the back seats. Any other suggestions?
Buy a different vehicle with more room to utilize. You may be able to make a taller enclosure to get more Cubes for a pair of tens possibly? and do an Aero Ported enclosure?? For a better sub?? You can always buy a different sub and try it in that enclosure.Be better sub up port up by looking at that pic and car. I wouldnt do too much. Im sure that roof is not very rigid in that car.
Could probably fit 2 10s or 4 8s which would give you more cone area.
The sa12 I've it's a v2 can handle a little more power but you are already above rms and any more power will rapidly kill it if you just get the wrong boosted song and send it to clip city.
You could likely raise tuning to about 36hz and gain on the meter without losing too much low end.
Put a new baffle on it and install two Sundown SA 10's. That will give you 40% more cone area.
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
746
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
Georgiaboygj
Georgiaboygj
Phoenix az
Georgiaboygj
maylar
    Jun 2, 2024
    Jun 1, 2024
