configuration problem with sub and DSP!
  • 2
surreal89
19
Italy
Some mono amplifiers indicate in the manual to use both RCAs, both left and right.
But if a DSP has only one channel available, what happens if I only use a single RCA?..I noticed that with a single RCA the sub signal is only present on one side of the scale.
By putting two perhaps the channels should be added to the mono.
But since I don't have two free outputs on the DSP perhaps I should use an RCA Y?.. in this way I connect the two signals which then add up into a single channel right?
But what happens instead by using a single RCA without adding the signal of both?..I'm interested to know if there can be an attenuation also in dB
Easy fix,
If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two inputs that are summed, it will affect the low level input voltage to the circuit and the output to the subs.
Which DSP, which amp?
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
756
I'd wire the SVC subs in series for an 8 ohm load. Wire the DVC subs coils in series for a 4 ohm load. Wire the 4 ohm and 8 ohm load in parallel...
Yes you can if you have all the connectors in the rear of the stereo. There should be a bunch of rca connectors plugged in the back of it and if...
The starting ask on diyca.com is $2,500, so no telling what they want in the end, maybe $500k lol. Funny that caraudio.com is no longer valid for...
19
76
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
911
surreal89
surreal89
Italy
    May 18, 2024
    May 18, 2024
