Converting a balanced signal into an unbalanced signal
  • 1
tonksie93
CarAudio.com Newbie
18
My headunit outputs a low level balanced signal but it is over 2 wires not 3 (there is no ground reference) but my DSP cannot accept a balanced signal. I’ve looked at converters online but the inputs all seem to be XLR connectors, which are 3 wire. How would i go about this??
As for a coned speakers (woof, midbass, mid) driver polarity, a common household D cell battery works great. Connect the batter to wires, touch...
5
845
Sounds like you shorted the other channel so check you connections. Don't ask just look. Will solve your problem Every time. If you ever short out...
9
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
u may be referring to the yellow wire and red wire. But there's a voltage drop just at the on position. So no signals come in via antenna. Or...
tonksie93
CarAudio.com Newbie
tonksie93
tonksie93
Dylan27
    Jun 4, 2024
winkychevelle
    Jun 3, 2024
