Couple of taramps questions
He's not wrong. Taramps work better with a 1.6-2.0v rca input signal. And that HU will not provide a clean signal at max volume with the sub output all the way up. Those are facts.
My MD8k's sweet spot was 1.8v rca input voltage. My teammates Bass8k's like 1.6v the best. And my old HD15k's actually liked 1.4v input.
I've never had my hu at max volume...
Just saying...
I'm new to taramps (and full bridge) but I got smart 3 installed...I've been running it about 2 weeks now and a couple things strike me as odd...
The fans start up when i power on but shut off right after...every other amp I've had with fans either stayed on when powered or never came on til the amp got hot...so I'm not sure if this is normal...
The other thing is the gain...even when turned all the way down I get good movement from my subs...they're rated 1200w for the pair and I got them wired to 4ohm...I'm figuring since the amp produces quite a bit more power then the subs need is why...but again this is the first amp I've own that turning the gain all the way down didn't effectively shut off the subs...
Everything sounds good...no floor noise from the amp...the subs are clean sounding...those 2 things just strike me as odd so I figured I'd ask...
All of this is normal with full bridge amps. I have a sundown SIA 2500 and the gain requires very little movement to reach 1800 watts.
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
Yea. I literally spent 2 hours perusing the site. Got to love a helpful website. I bet that they have thought of everything that could possibly...
933
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
spokey9
5 time International Booty Bandit Gold Meldalist
spokey9
NE AR
Bobbytwonames
    May 16, 2024
    May 16, 2024
