Cracking/popping
  • 4
254chamorro
I have a 84 c10 with a pioneer deh-x6800bt stereo receiver with 4 6.5 pioneer speakers attached. when I turn the volume up about 3/4 there is cracking and popping sound. I checked the harness ground and actually made a new point for ground. then I checked all the speakers polarity making sure positive and negative is connected from the stereo to speakers. speaker wires are new using regular speaker wire to all 4 speakers. also I connected a couple speakers to a boom box outside the truck and turn up volume but had no cracking or popping. anyone have any other steps I can take.
I'm curious how you connected a couple speakers to a boombox?
(your crackling/popping sounds like a lose connection around speaker terminals.)
Could be a few things
your wiring is either loose or has some tears in the line
Your head unit doesnt put out enough clean power and you need an amp.
I'd say its the wiring more than anything.
My rear 6.5 inch speakers are in a box so I was able to connect to a stereo I call it a boom box where it has removable speaker units as well. We'll I guess for one last test I'm gonna test each speaker with new wires temporarily. If it still makes the noise would it be safe to say it's the head unit? Also when I had them connected to boom box I cranked it up high louder than It gets in the truck before popping sounds.
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
416
Wow that is very very odd. Could be the wiring harness from them. Check the wires and possibly reground the stereo to another bolt in back of the...
13
Maybe your amp gain is set too high, or wasn't set properly with the head units volume adjusted properly prior to setting the gain since you...
10
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Yeah, I'd give them a call. They might replace it. If they do, that is huge CS. I've never known of any mfg to replace an amp because of complete...
17
254chamorro
254chamorro
Austin texas
254chamorro
