Crossover settings
  • 3
JonathanLopez
I have a Pioneer AVH-4000NEX receiver in my 2012 Challenger and it’s hooked up to the door speakers, tweeters in the rear, and the subs in the trunk. On the receiver there is a Crossover setting where I can adjust the Hz and slope for the front, rear, and sub, but I don’t know how they should be set. The Hz setting can range from 50-200 while the slope (dB/oct) can be set at -6, -12, or -18. Which values are optimal for the performance of the subs, tweeters, and speakers? Should they all overlap or is it best to have them all as separate as possible ?
You will have to play with it to see what you like the best, in the best setup I had with rear speakers the front ran from 100hz and up, the rear had 6x9's that ran 40-100 hz, and the sub ran somewhere around 33-80hz. But I did prefer the setup without any rear speakers, sub at the same maybe up to 100hz, and the fronts 80hz and up, I played with 60hz on the 18db per octave, but I think I settled on 80hz everything 12db per octave. Every car, speaker, and user combination will be different, thats why its adjustable.
For the front and rear speakers set the high-pass filter around 80-120 hz depending on what sounds better with over driving the speakers (you'll...
959
almost looks like it could be 180 degrees on one, and the other is about 120. IF SO, it makes me think the 180 under there would be the reason...
14
By Cook Cluuck Book 98.. You must have sound to be good before you can have decent sound. System is measured by how many ants move one piece of...
14
While we call the M3 Carbon our midrange it is actually a wideband loudspeaker capable of playing from 125 Hz up to 20,000 Hz. We recommend a...
JonathanLopez
JonathanLopez
Houston, TX
HoneyBadgerRy
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
