custom enclosure?
nemesismachine
im looking for a custom enclosure for my 93 civic. I want 2 12" MMATS juggernauts in the spare tire well, but im not sure if theres enough space in there for em to fire. has anyone any suggestions? i like the look of the subs in there, and with my amps on the sides of the trunk i still have plenty of trunk space.
Well sir. You could take everything out of your spare tire well. And fill it up with packing peanuts to find the volume. You may have to build a false floor to gain some airspace for your subs though. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks, ill try that tonight. as for the install, what works best? MDF? ive seen a few that i like, with the amps on the side and the subs in the well. nobody knows about em though. im not too good with fiberglass. if i try it, will it support the juggys? and not crack?
Use MDF for the baffle. And fiberglass the tire well. Build a square frame around the edge of the tirewell with some 2" x 2" stock. That way you will have an easy way to attach the baffle. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Nah go ahead and bring the resined mat over the wood, and glass the frame to your fiberglass tub. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
nemesismachine
nemesismachine
Washington DC
ramos
    May 31, 2024
    May 24, 2024
