Custom Subwoofer Box Three 15's
correct. 10.29 is counting what the woods takes up. and I've already included the sub displacement. Looking at 3.21 per subwoofer not counting the port displacement.
trunk dimensions. looking to do...60 wide x 16 high x 29 deep
Could look into an aero port.
trunk is 44x13x9 in the back 60x16x21 in the front..so 11.69cuft airspace...10.29 after wood....9.66 after speaker....i dont know the port displacement yet
this wont work?
you will have better output with 2 subs with the proper airspace and port size than 3 with the box and port too small for them
^^^ this
....3 subs installed sub par may under perform against to 2 of the same but done right.
also, the amount of bickering here is astonishing. calm them teataeys.
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Shelbywh89
Shelbywh89
Seattle,WA
Shelbywh89
maylar
    Jun 2, 2024
    Jun 1, 2024
