dc audio level 4xls
Well talked to rusty today and that should be fine. I just ordered a 15 lvl 4 XL today //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
dang thats alot, if it can do 3k, would the 1.5k im planning to throw on it even make it hit like it should?
Not really sure...you could build a bigger box to compensate for the lack of power....I ran one in a fart box(that i built the morning of the comp...stupid idea) and it laughed at 3krms...lol....
Straight from DC's website....
"Level 4 XL
This sub was developed out of demand.
We were getting a lot of requests for something bigger than the LV4 but doesn't kill the gas mileage like the LV5 80+ lbs subs. We were moving a lot of hybrid subs that used LV4 motors with LV5 coils but we knew we could do better than that.
So we thought, everyone likes the LV5, It’s a fantastic sub... Lets use it as the platform for an in-between sub. We played around with a smaller version of the LV5 - That’s exactly what the XL is... It uses all of the same soft parts of the LV5 with a smaller version of the same motor. Just small enough to squeeze through the cut-out hole for a 10" driver. What was the end result? A great sounding high powered daily driver sub that can be used in or out of the competitive lanes. The XL has devastating lows and reliability. It quickly became our best selling sub!
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• 8”OD semi cup progressive roll spiders
• Extra heavy duty interweaved tinsel lead wire
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly – Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 1ohm , 1.4 or 2 ohm 3” 8 Layer Hi-temp Aluminum voice coil wound on black anodized voice coil former"
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
I had a JL 600 what amp (XD600/1V2) and the JL Audio Remote Level Control Knob (HD-RLC) installed professionally and hooked up to a JL Sealed 10in...
A Link would be very helpful. Id be interested in taking a look at some gear
229
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
350
Arodd561
PALMBEACH
Arodd561
Jupiter,FL
plugitin
Decebal
    Jun 10, 2024
