Decided to strip my trunk and found this...
Once cured, Spectrum is odorless, waterproof, and extremely resistant automotive chemicals and is odor free. Spectrum will retain permanent adhesion in even the most extreme environments. Because it won't chip or crack under extreme temperatures or abuse, it can be used as an undercoating as well as an interior coating. Spectrum is also non-toxic, non flammable and has more anti corrosion and rust inhibitors that any other product onthe market.
that is what it says about spectrum, but it doesn't say that about sludge
lol wtf is that.
let us know how Second Skin resolves this issue.
i wouldn't post on the forum tho, thats alot of bad publicity. talk to Ant privately, no need to get him mad.
Bad publicity? Can't hide everything from the public. Do you work for the government?
This may not be a product issue. What Ice failed to mention is he has a spastic colon. And very often leaves excess amount of excriments in his trunk for prolonged periods of time.
Either that or god took a dump in his trunk, after hearing his sytem...
Keep us updated, I'm curious to hear what Ant says as well. Maybe an oxidizing reaction happened when it started to rust, and triggered an ingredient in the sludge to do that.
**** Ice, GL with that ****. That's the most disgusting thing I've seen in a trunk lol. Figure out where that waters leaking in from. See if you can sit inside the trunk with a light while your friend hoses it down while it's closed. That's how I found where my sunroof was leaking.
i'm not cramming my ass in that trunk. i should've asked the hoe i had in there the other night if anything was leaking
LOL!!
Thats how bad my hatch area was in my 240sx....it smelled bad and I didnt know what it was till i took out the carpet. It was brown water with all kinds of **** in it. Mold all over the carpet and to top it all off, a dead mouse under the carpet....YUM
Leaks FTL
Thats how bad my hatch area was in my 240sx....it smelled bad and I didnt know what it was till i took out the carpet. It was brown water with all kinds of **** in it. Mold all over the carpet and to top it all off, a dead mouse under the carpet....YUMLeaks FTL
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Stop keeping your bodies back there and you won't have a problem...
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
795
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
iceteebone
Banned
iceteebone
Michigan
iceteebone
    Jun 1, 2024
    May 31, 2024
