Dick wont work now?
check all the other fuses in the fuse box under the hood and inside the car, w/e they may be, you may have blown more that just the fuse on the new "dick". a cheap multimeter is 10 buxs, or digital is 20 at wally world
you blew another fuse. do your power doors work? domelight? when I blew a fuse screwing around installing a deck, it blew the car fuse that was linked to the stereo, power locks, and domelight. replaced that and all was back to normal.
look at the fuse diagrams and check all the ones that are basically interior accessories. Shouldn't take long.
If you had a multimeter, this process would take literally 30 seconds to check every fuse in the car, too. Would be a good investment if you plan on doing any 12v work.
I bet you just blew a fuse. I did it and couldnt figure out wth was wrong, then finally checked all fuses under the hood and it ended up being some fuse.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
That's the dd1 The dd1+ has only 4 tracks. I have the dd1+ , just got home. I think the dd1 has all those other tracks. Diff tool. So it says...
Id remove it at this point and bench test it on 12v
hdj20
F*CK SONY
hdj20
wisconsin
TMali
    Jun 1, 2024
    May 31, 2024
